2014 ford focusAugust 26, 2015Bought this and when you first eccelerate it has a shutter. Was told all there 4 cyl do this.Keywords:Focus1 thought on “2014 ford focus” Freeautomechanic August 26, 2015 at 9:11 am Is this a Manual or Automatic transmission?If it is a manual shift. It is possible that the flywheel has hot spots and it causing this issue. If it is an automatic transmission, you may be able to ad some “Shudder Fixx” for less than $10 to calm it down a bit. Comments are closed.previous1998 Buick Skylarknext2002 Ford Taurus
