I just replaced my battery and filled the fuel take about 15 minutes after filling the tank i was stopped at a stop sign when i went to go the car died. It will crank but it will not turn over. What could be the problem?
Keywords:wont start
An Engine needs 4 things to run
1) fuel
2) spark
3) compression
4) timing
Could be a lot of things. You will need to determine if it is getting fuel(injector pulse) or spark or if the timing belt broke.
No Start Diagnostics
