Home » Car Questions » 95 dodge dakota
95 dodge dakota
how many quarts of tranny fluid needed with 3.9l v6 magnum
1 thought on “95 dodge dakota”
  1. 5 typically if you are just changing the transmission fluid and filter. If you have drained the torque converter you may need an additional 4 to 5 quarts. It is a good idea to add the fluid and check the level with the dipstick after each quart.
