Home » Car Questions » 95 dodge dakota95 dodge dakotaAugust 22, 2015August 23, 2015how many quarts of tranny fluid needed with 3.9l v6 magnumKeywords:dakota1 thought on “95 dodge dakota” Freeautomechanic August 24, 2015 at 10:01 am 5 typically if you are just changing the transmission fluid and filter. If you have drained the torque converter you may need an additional 4 to 5 quarts. It is a good idea to add the fluid and check the level with the dipstick after each quart.Comments are closed.previous2001 Skoda octavia estate, 2l, petrolnext1981 vw rabiit convertible w/ automatic transmission
