Home » Car Questions » ’03 Nissan Altima S
’03 Nissan Altima S
I had the transmission replaced on my Altima a couple months ago. Now the car raddles when i go over a bump. I got under the car to figure out the problem, found that there is a fingure width gap between a mount on the front frame and the bracket for it. Is there suppose to be some rubber spacers to keep that from striking metal on metal?
1 thought on “’03 Nissan Altima S”
  1. Shouldn’t be any metal on metal. You may want to return to the installers and see if they forgot to install it and may have found it laying around the shop. If you have a picture add it from the edit menu.
    Is this the 4 cylinder or 6 cylinder engine?
