Intermittent transmission slipping. No evidence of water/fluid cross contamination. Changed Trans filter. Worked good for one day then intermittent again. Problem appeared suddenly.
Keywords:Pathfinder
Was the fluid burnt looking when you changed the filter? if it was, it may need to be rebuilt.
If the fluid looked good, may be a shift solenoid hanging up or a Speed Sensor failing. May want to have a transmission shop pull any codes it may have stored in the computer.
