got front brake pads yesterday. no longer squeels when braking but started squeeling when turning. has gotten a lot worse. no indicator light on. steering fluid ok. Grandson says it’s not the coil springs. Steering & brakes operating ok but noise has gotten louder. What might it be?
Keywords:Blazer
Sounds like you may have a backing plate rubbing. This is common as the backing plate is thin and bends easy. It tends to get bent when removing the wheels and goes unnoticed. I would check this first. You may need to put the car on jack stands and turn the wheel and spin the tire and inspect that area.
Reference : Troubleshooting Brake Problems
