I have a 1996 Chevrolet Corsica 3.1L. Today I replaced the coolant as the Low Coolant light was going on and off all day. Still said Low Coolant after. Tried starting it a minute ago, speedo slowly went all the way to 120 by itself (still parked) it died and would not turn back on. Please help, I need it for work. Thank you.
Keywords:Corsica
Sounds like a battery issue. You must have left the hood up or the door open for some time while messing around with the coolant. Check the battery first and make sure it is charged or replaced. I use a 100 amp battery load tester to check mine.
Follow the image for more Details…
No Start Diagnostics
