My #3 injector is not pulsing. It has a wire ran straight from the injector to the computer. It worked for a little while and the wire was cut when the head was fixed and now it’s dumping gas again. The injector was replaced and I put another computer in it. What else could it be?
Keywords:eclipse
The wiring. May have a short in the ground or power. Keep in mind the signal that comes from the computer is a negative signal and the constant is battery positive. Use the wiring diagram to help trace the wiring.
How to use a multi-meter
1996 Mitsubishi Eclipse 2.0 L Fuel Injection Wiring Diagram
