my brakes quit working. i replaced the master cylinder, and bled the brakes, but when you step on the peddle there is nothing there. no pressure, no brakes, the peddle just goes to the floor.
Keywords:s-10 blazer
Brake pedal height is adjusted by the rear brakes if it has drum brakes. Make sure they are adjusted. Then if the pedal still goes to the floor, the New master cylinder is bad, there is a leak in the lines or there is still air in the system.
Did you bench bleed the master cylinder?
Troubleshooting Brake Problems
