Dropped valve seat. bought new head. took out all the lifters. put them in oil. is there a specific order they go back in
Keywords:Focus
You should have marked them when you removed them so that they end up in the same spot on the cam that they were in before. If you did not do this, then it isn’t gonna matter as you can not tell where they came from. Just put them back in and go.
