Home » Car Questions » 2004 ford ba falcon xr6 auto
04 ba xr6 automatic ford falcon makes a high pitched squeeling noise when reversing or crawling at very slow speed like traffic lights . Noise will stop when I touch the brake. In the last week car hasnt been starting on first try so I remove key and restart on the ocassion it doesnt restart first time wich has happened twice I repeat removing key and restart.on the 2 times that it hasnt restarted straight away and taken a couple of tries to start I cant even drive 3 mins down my street and I have no power to drive the car maybe 5km a hour if that and a orange engine light will come on. I stop restart bit sluggish but starts. Any idea im booked into a mechanic but as they are busy its not for 2 weeks
1 thought on “2004 ford ba falcon xr6 auto”
  1. The computer codes for the check engine light would help guide us tot he problem areas. If the noise quits when you hit the brake pedal then there is an issue with the brakes and may require replacement of the brake pads and possibly the rotors.
    Brake Troubleshooting
    The starting issue and loss of power would require pulling the codes before diagnoses can be done.
