Toyota Siena 2000
Can the vehicle ABS expire? If yes how do you repair or replace?
1 thought on “Toyota Siena 2000”
  1. The ABS can fail or a component/sensor can fail. If any part of the ABS fails the ABS light will illuminate on the dash. When this happens the ABS will no longer function until repaired. A Diagnostic Scan Tool that reads ABS codes is required to diagnose the issue.
