Home » Car Questions » 1993 s10pickup
1993 s10pickup
how can I tell if my timing chain as broke or if it jump time are if it is something else.
1993 Chevy S10
1 thought on “1993 s10pickup”
  1. First it might be nice to know what the problem is and what the engine size is?
    Quick test to see in the timing chain is broken:
    1) Remove the distributor cap
    2) Crank engine and monitor to see if the rotor rotates or not.
    No movement would indicate a broken timing chain or camshaft.
    Movement would indicate timing chain intact.
    Test to see if the distributor jumped time:
    1) use a timing light to check timing components.
    To check for something else such as check Chevy engine codes
