Home » Car Questions » 1999 fiat coupe 20v turbo
Just changed head gasket and the battery was off for a while now its all back together but the car turns over but wont fire injector light on the dash is on but cant locate obd plug. Plugs have no spark and all indicators go of when they feel like it as if the alarm is still set need help fast!!!
1999 Fiat Coupe
1 thought on “1999 fiat coupe 20v turbo”
  1. Try this:
    disconnect the battery. Put key in the “ON” position.
    Reconnect battery. Move key from”ON” to “START”,
    should be good to go. If no change, check the ECM fuse and all fusible links.
