The rear end of my Saturn jumps sideways when I hit bumps. I thought it had stabilizer bars or a sway bar back there but apparently not because, I can’t find any! I can’t even find a decent diagram to help me map it out. Please, if you can, help me.
2000 Saturn SL1
Keywords:SL1
This vehicle uses stabilizer shafts on each side in place of an anti-sway bar. The reason is the car has independent rear suspension. I dug you up the replacement procedure for replacing them. It shows plenty of diagrams to give you an idea of where to look on your Saturn.
2000 Satrun SL1 Stabalizer Shaft Replacement
