Home » Car Questions » 2001 Dodge Ram 5.22001 Dodge Ram 5.2October 27, 2015Can I reroute my brake lines to eliminate ABS system.Keywords:Ram 15001 thought on “2001 Dodge Ram 5.2” Freeautomechanic October 27, 2015 at 10:02 am If you wanted to do so you could. If you are just looking for ABS operation to no longer work just unplug the ABS relay in the under hood fuse panel. Just a note, anytime the ABS light is on the ABS function is turned off and will not operate.Comments are closed.previous1993 s10pickupnext1997 Nissan Altima
