Home » Car Questions » 2003 ford explorer2003 ford explorerOctober 5, 2015October 6, 2015My truck makes a really fast loud grinding noise when I go to start it and it won’t start. if I try again, it starts fine with no trouble. What could be wrong?Keywords:Explorer1 thought on “2003 ford explorer” Freeautomechanic October 6, 2015 at 9:04 am Sounds like you may have a broken tooth on the flywheel or the starter itself is going out. A visual inspection is needed to check the flywheel.Comments are closed.previousBmw 750linextperouda kenri
