I am rebuilding an engine for this vehicle, it is the 2.0T FSI engine, and i am replacing the timing belt, water pump, timing chain, tensioner, and head gasket. I need to know all fo the related torque specs and sequences, as well as what bolts involved are stretch bolts and will need to be replaced
Head torques sequence as follows:
1) tighten the bolts a first pass to 40 Nm
2) tighten the bolts a second pass an additional 90 Degrees (1/4 turn)
3) tighten the bolts a final pass an additional 90 degrees (1/4 turn)
Head bolts need to be replaced for stretching.
