Glow plug light is changed plugs no joy cleaned EGR no joy checked to see if fuel is coming through its fine can you help.
2007 ford mondeo tdi
Keywords:Mondeo
If a light is on the dash it may require a scan tool to extract the codes for the information needed to access the issue. If the injector pump is not working it will cause the engine to fail to start. Is the problem you are having a no start issue?
