Home » Car Questions » 93″ honda accord
93″ honda accord
1993-honda-accordcar turns off after running 15 min. I tried changing ignition coil,
1 thought on “93″ honda accord”
  1. The ignition control module is the most common failure part for this issue. What happens is the control module gets hot and stats to break down. Usually once it has cooled down it will restart and run until hot again. Replacing the part should take care of this issue.
