Home » Car Questions » 1998 oldsmobile 88
1998 oldsmobile 88
1998 Oldsmobile 88
What would make my car break ac compressor bypass pulleys.
1 thought on “1998 oldsmobile 88”
  1. 1998 Oldsmobile 88 serpentine belt routing diagram
    If it has an aftermarket bypass pulley you may need to check with them for proper installation tips and or warranty. If you are just talking about the outer ring on the air conditioning compressor that normally allows the belt to just free spin, there are a couple of reasons for it to lock up. Number one cause of locking up would be age and use. Number two cause would be bearing failure. And number three would be climate/rust.
    You can still get parts for this so at least that doesn’t become an issue. You can pick up an actual OE part. Follow the image for more Details…
