I was driving today and my car just started cutting back. it wouldn’t get over 30 mph. and when I would try to accelerate my speed would drop instead. any ideas on what could be wrong?
Sounds like your running out of fuel maybe. But first if there is a check engine light on, you would want to pull the codes first. You need a code reader to perform this task or stop by just about any local auto parts store and they will do it for free. Then post the trouble codes below.
Possible clogged fuel filter, or catalytic converter. Possible fuel pressure loss from pump. MAF sensor failure. Loose hoses or vacuum leak…..
