Home » Car Questions » 2004 ford crown vic 4.6 liter2004 ford crown vic 4.6 literNovember 19, 2015November 19, 2015What causes the OBD 2 scanner not to be able to link to the vehicle on a 2004 ford crown vic 4.6 liter?Keywords:Crown Victoria5 thoughts on “2004 ford crown vic 4.6 liter” FreeAutoMechanic November 19, 2015 at 7:12 pm There is one fuse that will create this problem. Fuse #105 30Amp. The fuse is normally hot at all times(should show battery voltage). shianne333 November 19, 2015 at 7:20 pm the plug in has power, but the scanner is reading unable to link to vehicle FreeAutoMechanic November 19, 2015 at 7:21 pm Does the #105 fuse have battery voltage? You either have a blown fuse or bad connection or bad scanner or bad PCM. Let me get you a wiring diagram… shianne333 November 19, 2015 at 7:26 pm any suggestions? FreeAutoMechanic November 19, 2015 at 7:30 pm Does the #105 fuse have battery voltage? You either have a blown fuse or bad connection or bad scanner or bad PCM. Let me get you a wiring diagram so you can find it easier to trace the wiring if need be.2004 Ford Crown Victoria Data Link Connector wiring diagramComments are closed.previous2008 subaru imprezanext2004 Ford Crown Victoria data link connector wiring diagram
any suggestions?
