2005 Toyota Sienna
it is a 2005 sienna that slips between second and third, what will it take to repair?2005 Toyota Sienna
1 thought on “2005 Toyota Sienna”
  1. If the transmission fluid color is dark and burnt smelling, the fix would be to have the transmission rebuilt or replaced. If the color of the transmission fluid is clean and clear then you are probably looking at a failing shift solenoid. A transmission shop can scan for codes to determine what the issue is.
