Home » Car Questions » 2006 PT CRUISER
2006 PT CRUISER
2006 Chrysler PT Cruiser
CAN I INSTALL AN OIL PRESSURE GAUGE IN MY 2006 PT CRUISER?
3 thoughts on “2006 PT CRUISER”
  1. I don’t see any reason why not. All you need is one of these electric oil pressure gauge kits and a little time. You would remove the factory oil pressure switch (3) and install and adapter that will allow the factory switch and now your new oil pressure gauge sending unit. Run some wire from the sending unit tot he gauge you have mounted and your set.
    oil pressure switch location
