You have the option of having it replaced. At the very least you may want to look around and make sure there are no obstructions. Wiggle the fan blade to see if the bearings int he motor seem loose. Replacing the fan motor assembly should take care of it.
there seems tbe two speeds slow speed is ok the faster speed is noisier and the car owner says she never noticed it befrore . she had thermostat replaced and now notices the noise
May want to take a look at the fan blades themselves to see if they have any cracks in them . If they do, replace the fan. If not just keep an ear out to see if it gets any worse. Also a good idea to keep an eye on the temperature gauge to make sure it doesn’t over heat.
2007 Ford Fusion cooling fan motor and shroud replacement.
The cooling fan in your vehicle is controlled by the PCM – Powertrain Control Module and uses only one input signal from the ECT – Engine Coolant Temperature Sensor.
