Home » Car Questions » 2011 elentra auto trans
2011 Hyundai Elentra
Gear shift will not shift to low gears. trans shifts normal is all other gears. I think the selector is a electronic shift on the fly system? Does the shifter operate a sensor or relay to the trans. Where is it located if you know? thanks.
1 thought on “2011 elentra auto trans”
  1. The correct operation of the transmission is listed in the owners manual generally located in the glove box or can be viewed online from an online owners manual. The shifter moves and activates the up shift button or the downshift button but ONLY when “Sport Mode” switch is selected. The buttons send a signal directly to the PCM – Powertrain Control Module(left rear of engine compartment). then the PCM controls the electronic shift solenoids inside the transmission.
    Transmission Code: Trans Mfr CD A6GF1
