The heater blower fan will not shut off, even when I turn off the car and remove the key. For about a month, it was operating only in the high speed setting.
To turn off the fan, I have removed the fuse from the block inside the passenger door.
When driving the gauges gyrate and the dash lights flicker. Under acceleration the headlights dim. After some driving distance, the…
Fog Light Replacement Unplug electrical connector from fog light assembly Remove 13mm retaining nut and washers from fog light under…
If you haven't heard already, GMThe agency said that without the warning light, a vehicle may be driven with low…
https://youtu.be/Svf620OlWF0 This video is the rear section of the frame kit installation. https://youtu.be/Z7uBahE6hoY This video is of the center section…
Hi, just following up on 02 Caravan: I was scanning with the newest up date and not the vin# so…
View Comments
The fan only working on the high speed setting will require replacing the blower motor resistor.
The resistor is located next to the blower motor in the ventilation box behind the glove box. One wire connector and couple of screws and your done.
To fix the blower motor not turning off, all we need to do is replace the blower motor relay because it is sticking. The blower motor relay is located in the under hood fuse block.
Just pop the old one out and pot the new one in. It will take you longer to get the hood up than it will to replace this relay.
Probably do the relay first. I can live with a one speed heater fan, as long as I have heat this winter! The resistor can wait a little while, I hope.
Thanks!
