Categories: Hyundai
hyundai h1 9 seater bus 2012
2012 Hyuandai H1 Minibus
My check engine light is on, the computer say it the starting sensor I have change it reprogram the vehicle computer drive for ten minutes switch off the engine and when I start up again it comes on and stay on, what is causing this?
Keywords: H1 9 Seat Bus
Sam Rogers
View Comments
  • After a little research it seems that many Hyundai's of 2012 are having the same issue. It may very well be the crank sensor. Replacing it may cure the issue. If it is still drivable it may suffer poor fuel mileage.
Recent My Questions
2000 Honda Civic engine shutters and electrical accessories will stop working
When driving the gauges gyrate and the dash lights flicker. Under acceleration the headlights dim. After some driving distance, the…
1 day ago
LED Fog Light Upgrade Jeep Wrangler Video
Fog Light Replacement Unplug electrical connector from fog light assembly Remove 13mm retaining nut and washers from fog light under…
3 days ago
GM Low brake fluid warning light RECALL – How soon should I get it fixed?
If you haven't heard already, GMThe agency said that without the warning light, a vehicle may be driven with low…
1 month ago
Jeep Wrangler Frame Repair Kit Installation Video
https://youtu.be/Svf620OlWF0 This video is the rear section of the frame kit installation. https://youtu.be/Z7uBahE6hoY This video is of the center section…
2 months ago
02 Grand Caravan Sport
Hi, just following up on 02 Caravan: I was scanning with the newest up date and not the vin# so…
2 months ago
