Home » Car Questions » 05 dodge durango 4.7
2005-dodge-durango
It wont start unless the gas pedal is half way to the floor, and it hesitates or bogs down when it gets to 2500 rpm
1 thought on “05 dodge durango 4.7”
  1. First thing if the check engine light is on, you will need to have the trouble codes pulled. Most any shop and many local auto parts stores are able to perform this task. Post any codes found below.
    No light on, Most likely reason would be a vacuum leak or the idle speed control (IAC – Idle Air Control)
