Do not need to change anything. The long block of the 305 and 283 are the same. You just swap over all the accessories that you already have on the car the engine you put in it. All is the same and will bolt up just fine.
Long Block Chevy 283-305-327-350 of the similar years will work. Same exhaust, wiring, intake, etc.
