turn on headlights and blows a fuse
need to know what to check to find what is causing blowing fuses when turn on headlights
You will need to trace the wiring that is involved with the fuse that is blowing. Using a multi-meter will make it easier to locate problem. Here is a wiring diagram to help with this task.
1995 Chevy S10 Headlight wiring diagram
How to use a multi-meter
