1996 Toyota CamryDecember 12, 2015December 14, 2015 Ignition not firing what to check? Car quit running goning down the road and now the engine is no firing.Keywords:CamryNo Startnot firing1 thought on “1996 Toyota Camry” FreeAutoMechanic December 14, 2015 at 10:26 am Check the ECM fuse. Check your wiring from the ECM to the ignition coil and distributor.Here is the wiring diagram of the engine control system:1996 Toyota Camry 2.2L engine controls wiring diagramComments are closed.previous2000 toyota avalon 6cylnext1999 ford escort
