My truck died while driving, won’t restart, has fuel, fire, air & got compression. I’ve changed the crank sensor, spark plugs & have no codes. Any guess what it could be? thanks
If you have spark and compression, try spraying in some starting fluid in the air filter(use plenty). If it starts, then I think you are missing injector pulse. I use an injector pulse tester like this. You just touch the tip to the injector and crank the engine over.
