87 ford f150December 5, 2015 Crank no start, died on way home, wouldn’t start back up, tried jumping battery, no good, towed home.Keywords:F-1501 thought on “87 ford f150” FreeAutoMechanic December 5, 2015 at 2:23 pm Most common reason for this would be the ignition control module. Under the hood, couple of bolts and connectors and your done. Try pulling the check engine light codes. You can do it yourself without a scantool. Post any codes that come up below. Here is how:Pull Ford Check Engine Light CodesComments are closed.previous1999 DODGE DURANGOnext97Gmc 2500,5.7
