Home » Car Questions » ikco sammand (xu7jp 1.8i peugeot 405 engine)
the engine won’t  run more than 3000 rpm when the car is not at the neutral gear, but at neutral gear the engine can acheive even 5500 rpm ,help please !
1 thought on “ikco sammand (xu7jp 1.8i peugeot 405 engine)”
  1. If the check engine light is on , the codes will need to be read and posted below.
    If it feels like the brakes are dragging it might be just that. Put vehicle on jack stands and see if the wheels spins freely by hand when put in neutral.
