The switched off while the engine was running and it can’t start. 30A fuse found burnt what may be the cause and how can I fix it.
Replacing the fuse may enable you to start the engine however you will need to determine the cause of the fuse to blow. A direct short or an amperage draw that exceeds 30A is required to blow the fuse. Trace the wiring on that circuit to eliminate the possibility of a short.
