The car seems to be to accelerated also when it shifts gears while in drive it takes some time to shift the engine has motor oil and it has transmission fluid. Also the idle seems to be to high. And the car jumps when its shifted from park to drive and reverse.
The high idle indicates an engine vacuum leak. This would cause the transmission issues and jumping in gear.
