Home » Car Questions » Toyota Tacoma . p. r ,2003
2003 Toyota Tacoma
power steering noise it new pump and lack it new still noise why???
1 thought on “Toyota Tacoma . p. r ,2003”
  1. Not sure why you replaced the power steering pump to begin with? But, I would guess if the power steering pump was and still is making a whining noise that the fluid level may be low, the power steering system was not bled after the new pump was installed or there is a leak in the system allowing air in.
    How to check your fluid levels
