Home » Car Questions » 1992 jeep charokee1992 jeep charokeeJanuary 6, 2016 having a issues with my ignition key stuck in acc. jiggle shifter, moved steering wheel. no luck.Keywords:Cherokee1 thought on “1992 jeep charokee” FreeAutoMechanic January 6, 2016 at 12:34 pm Apply graphite lubricant sparingly through the key slot. Insert the key and operate the lock several times to be sure that the lubricant is worked into the lock cylinder.Worst case you will need to replace the key/lock cylinder. Comments are closed.previousFord escort zx2nextHonda CR-V Exhaust
