Home » Car Questions » Power Loss Mercury Mountaineer
1999 Mercury Mountaineer
I have a 1999 Mercury Mountaineer 5.0L V8. It just recently began acting up. After warming up the engine goes through heavy power loss and inability to climb ANY hill. Usually cannot get above 30-35. I just recently replaced plugs and wires for a tune up and a faulty coil pack (approximately 5-6 weeks ago) causing a misfire on cylinder #8. Today in troubleshooting I attempted the “Backyard Mechanic” trick of unplugging the MAF sensor and took it down the road, no change at all in acceleration issues or on idle, truck runs the same. Unable to spot any exhaust or vacuum leaks or issues, recently cleaned MAF housing and changed Air Filter as well. All of these issues arose after a heavy ice storm, do not know if this had any impact or was just bad timing. I need help, any ideas??
I see you stated you cleaned the MAF sensor. More damage is done trying to clean the MAF sensor than good. However unplugging the Sensor should have kicked the check engine light on and forced the closed loop mode and run fine. Since it did not do this the next thing I would check would be the fuel supply. Check fuel pressure, etc. Might try power braking against a building while someone sprays a shot of starting fluid in the air filter to see if the engine revs or bogs.  If it revs, the engine is starving for fuel. If it bogs, then you know it is not starving for fuel. Move to checking the exhaust back pressure at the O2 sensor ports. 1 1/2 psi is normal, anything 3 psi or more is a restriction.
Back Pressure Tester
This back pressure tester can easily fit anywhere you need it to with its flexible hose. Less than $40 and includes free shipping. Follow the image for more Details…
  • Test for clogged or obstructed catalytic converters and mufflers
  • Threads into Oxygen Sensor Port
  • Kit includes 12MM and 18MM adapters to fit most domestic and imported vehicles
back pressure testback pressure tester
