HI, I have a 2008 Suzuki Forenza. The other day I went to shut it off and it would not shut off. In order to get it to shut off I had to pull the positive and wiggle the fuse box that is under the hood. I unhooked the alternator and started the car and tried to shut it off but it still would not shut off. It also keeps frying the stop lamp fuse.
More than likely you have a relay sticking. They are located in the under hood fuse block.
