In my Subaru Outback I have to remove the tail light fuse each night or it will drain the battery. How can I fix this..
This is the outcome of a problem with the tail lamp relay which is not unusual for the Subaru Outback. The relay gets stuck, even though the key is out, and allows the battery to power the tail lights and parking lights till eventually the battery discharges completely.
Subaru Outback Problems
Complaints of check engine light on, cruise control blinking, and no acceleration.
The car tends to loose power and may occur while driving at highway speeds. The most common fix for this would be to replace the pedal assembly including sensors.
