Home » Car Questions » Radiator Hose 2004 Ford Explorer
Radiator Hose
I have been putting water in the coolant reservoir of my 2004 Ford Explorer and because of the cold temperatures the water froze up. And now the upper radiator hose popped off and is frozen. Is my radiator damaged too? I don’t have the money to replace the engine or hose right now. What can I do?
Not a good idea to put straight water in the cooling system. One, it will freeze as you are now aware. And two, the water pump bearings are no longer being lubricated. Radiator should be OK but checking for leaks once it is repaired wouldn’t hurt. You will need to thaw out the engine and drain the cooling system. Reattached the upper hose and secure it with a radiator hose clamp. Refill the cooling system with 50/50 mix coolant.
Radiator Hose
Removal
  1. Drain the cooling system.
  2. Recover the A/C refrigerant. For additional information, refer to Air Conditioning.
  3. Remove the cooling fan. For additional information, refer to Radiator Cooling Fan.
  4. Remove the parts in the order indicated in the following illustration and table.
Radiator hose diagram 2004 Ford Explorer
Installation
It is OK to apply some lubricant when installing a radiator hose.
  1. To install, reverse the removal procedure.
  2. Fill and bleed the cooling system.
  3. Evacuate, leak check and charge the A/C system.
