Home » Car Questions » Paddle shifter GMC Terrain
2010 GMC TerrainPaddle shifter won’t work on my 2010 GMC Terrain slt 6cyl.. Whats the cause and repair?
The paddle shifter utilizes the up and down switches that sends signals to the body control module(BCM). Could be any part of the circuit. The switches, the BCM, the wiring harness or as simple as a fuse. Each will need to be checked to determine the exact cause before the repair can be made. Of course it would be great if it was just a blown fuse causing all the issues so be sure to check that first.
Paddle Shifter Wiring Diagram
Use the wiring diagram provided to trace the wiring harness and gain a better understanding of how the switches signal the transmission through the BCM.
paddle shifter wiring diagram
