Home » Car Questions » Engine Replacement 2000 Honda
2000 Honda CR-VNeed an engine replacement in my 2000 Honda crv ex 4 wd. What engine do I look for? How much should a used engine cost?
I recommend having a re-manufactured engine installed. The Honda CR-V came with a 2.0L engine and should be replaced with a 2.0L engine. A used engine is what you had 2 days before you found out you needed a new one.
Engine Assembly (New or Rebuilt), Replace (complete) Labor Time:
Labor Times
CommentsFactoryRegularSevere
0.012.812.8
Addons
w/AC add0.00.30.3
Replace camshaft and rocker arms  add0.00.50.5
Engine Replacement
2000-honda-crv-engine-removal
