I was going up my drive way. I got on the gas and my truck stalled on me for the first time. I put it in park and it started right back up. I am curious what caused this any ideas?
Hard to say. Could be a glitch. Some moisture in the fuel. Loose wire somewhere. Vacuum leak. Sticking IAC – Idle Air Control.
At this point there is not much you can do. If the check engine light came on, you could check the codes. Other than that you will need to drive it until it gets worse or repeats itself more often in order to diagnose it.
