I think someone put a TEE in the vacuum line for the brakes and put water down the hose so I have water in my engine, it’s not seized up but how do I get the water all out and get my car running again?
Change the engine oil, run the engine for a couple hundred miles and change it again. Do not run the engine until you change the oil.
Signs of water in oil
- Oil level will be higher than normal or show over filled on dipstick
- Oil will appear milky
