How do I access right side headlight bulb?
Headlight 2007 Jeep Wrangler Replacement
- Disconnect and isolate the battery negative cable
- Remove the grille panel from the front of the vehicle
- Remove the four screws (4) that secure the retainer (3) and the headlight unit (2) to the mounting collar (1) on the face of the front end module carrier
- Pull the retainer and the headlight unit away from the front of the vehicle far enough to access the wiring connection on the back of the light housing
- Disconnect the engine compartment wiring harness connection from the headlight bulb connector receptacle and from the position light bulb pigtail connector (5)
- Remove the headlight unit form the vehicle
2007 Jeep Wrangler Grille Removal
- Twist the center of the push pin insert to release and remove the six push pin fasteners (1)
- Using a trim stick or equivalent, release the lower clips (3) and separate the grille from the front end module
- Disconnect the electrical connectors (4)
